bonanza
#1 Posted : Thursday, December 11, 2008 9:33:09 AM(UTC)
bonanza
my dishwasher will fill, but not proceed past the "Heating Water" cycle. Pump seems to work to drain upon cancelling wash, but will not proceed to the wash cycle.
Drags1998
#2 Posted : Thursday, December 11, 2008 11:30:30 AM(UTC)
Drags1998
Check the heating element, If its not working OR the water is not HOT enough, It will NOT advance!!!!
bonanza
#3 Posted : Thursday, December 11, 2008 12:01:45 PM(UTC)
bonanza
is there more than the one heating element listed in the parts list as "heating element"?
#4 Posted : Thursday, December 11, 2008 1:11:17 PM(UTC)
Here is your parts breakdown
Model KUDS230BAL0
Item 1 in the "HEATER" section is the one used to heat the water.
The other one is for air dry. See "BLOWER" section
Here is the tech sheet
https://www.servicematters.com/d...0Sheet%20-%209742248.pdf
