AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Clothes get hung between drum and front drum bearing
Occasionally clothes will get hung between front drum bearing and drum resulting in black marks on clothes and sometimes tearing of item. I have checked the drum and there is no back and forth play, but there is up and down play. Just wondering if it is only the front drum bearing that is worn or if there is another part that may be worn. Dryer dries clothes just fine, it is just the problem of clothes getting hung.
Originally Posted by: jackpeg  Occasionally clothes will get hung between front drum bearing and drum resulting in black marks on clothes and sometimes tearing of item. I have checked the drum and there is no back and forth play, but there is up and down play. Just wondering if it is only the front drum bearing that is worn or if there is another part that may be worn. Dryer dries clothes just fine, it is just the problem of clothes getting hung.
Thanks Jackpeg, This happens occasionally, is it possible you may be overloading the drum, does it seem the happen with certain types or sized loads ? Replacing the front drum slides would eliminate the dryer as the problem, Part number: AP631382
Thanks for the info. The problem seems to occur regardless of load size. Since I will have the front apart to replace slides, I think that I will also replace the front bearing since the dryer is as old as it is. That should take care of any problems for a long time.
Originally Posted by: jackpeg  Thanks for the info. The problem seems to occur regardless of load size. Since I will have the front apart to replace slides, I think that I will also replace the front bearing since the dryer is as old as it is. That should take care of any problems for a long time. Jackpeg, Thanks for the update. I have to agree with you, Replace the bearings and slide, you should be fine then. :) :) :)
Dryer Repair
