what part do i have to buy when theres a heater temperature control problem in my gas dryer?
Originally Posted by: isaiah  what part do i have to buy when theres a heater temperature control problem in my gas dryer? Isaiah, You may not need a part at all. The "t5" code is actually a "TS" code, indicating the "thermistor is shorted". The thermistor is located on the front of the blower housing, in the inside of the dryer. It should have a resistance reading of 10,000 ohms at room temperature, on a multimeter. Part number: AP4045224
If you have a clogged dryer exhaust vent, dirty lint filter, or the machine is overloaded, it can cause the TS code to display. You'd be best off to check that first. Your technical data sheet, should be taped to the back of the dryer, and you can use it to reset the control and run the other various tests. Good Luck, :) :) :)
