kjp1015
#1 Posted : Wednesday, July 27, 2011 4:13:24 PM(UTC)
kjp1015
Stopped making ice in June. I replaced the Icemaker. Fixed !!! Making ice great for 5 weeks.Just stopped again.and now no water from dispensor either.
Now I replaced the water valve and the water line to icemaker. Started making ice slow but not working properly.
I checked the water line to see if its crimped & it is not!
I have the Feezer temp set on 7 out of 9.
Any Help???
#2 Posted : Wednesday, July 27, 2011 5:31:29 PM(UTC)
What happens with the dispenser lights when you depress the water dispenser lever?
How old is the water filter?
What is the exact temperature in the freezer?
Here are the breakdown diagrams and Replacement parts for General Electric GSL25JFPABS Refrigerator | AppliancePartsPros.com
kjp1015
#3 Posted : Thursday, July 28, 2011 12:05:13 PM(UTC)
kjp1015
Water filter replaced in December 2010.
But i took it out & placed the by-pass in & still no water.
I have 3 choices only-
Crushed ice -Reg Ice cubes -Water
Lite is green for whatever is selected. Stays green when I depress for water.
kjp1015
#4 Posted : Thursday, July 28, 2011 12:08:59 PM(UTC)
kjp1015
Temp in freezer is 10 degrees
#5 Posted : Thursday, July 28, 2011 12:59:23 PM(UTC)
...Started making ice slow but not working properly...
The ice maker needs about 0°F temperature. So, 10°F will definitely slow down ice production. You have to investigate why it's so warm in the freezer.
kjp1015
#6 Posted : Thursday, July 28, 2011 2:08:27 PM(UTC)
kjp1015
Where do I start. The freezer has always been set on 7 & worked fine.
what about the water., its not working. worked fine whejn I replaced the ice maker.
#7 Posted : Thursday, July 28, 2011 2:48:15 PM(UTC)
It might be two separate problems. The temperature in the freezer is more important because of food inside.
Make sure the condenser coils are clean and the rear cover is in place.
Remove the rear panel inside the freezer and check how the evaporator coils are covered with snow/frost. Normally it suppose to be about 100% covered with thin snow. Post the results.
Guest (7)
