Stopped making ice in June. I replaced the Icemaker. Fixed !!! Making ice great for 5 weeks.Just stopped again.and now no water from dispensor either. Now I replaced the water valve and the water line to icemaker. Started making ice slow but not working properly. I checked the water line to see if its crimped & it is not! I have the Feezer temp set on 7 out of 9. Any Help???
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Water filter replaced in December 2010. But i took it out & placed the by-pass in & still no water. I have 3 choices only- Crushed ice -Reg Ice cubes -Water Lite is green for whatever is selected. Stays green when I depress for water.
Originally Posted by: kjp1015 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Water filter replaced in December 2010. But i took it out & placed the by-pass in & still no water.
Lite is green for whatever is selected. Stays green when I depress for water. Temp in freezer is 10 degrees
Originally Posted by: kjp1015 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ...Started making ice slow but not working properly... The ice maker needs about 0°F temperature. So, 10°F will definitely slow down ice production. You have to investigate why it's so warm in the freezer. Gene.
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) The ice maker needs about 0°F temperature. So, 10°F will definitely slow down ice production. You have to investigate why it's so warm in the freezer.
Gene. Where do I start. The freezer has always been set on 7 & worked fine. what about the water., its not working. worked fine whejn I replaced the ice maker.
It might be two separate problems. The temperature in the freezer is more important because of food inside.
Make sure the condenser coils are clean and the rear cover is in place.
Remove the rear panel inside the freezer and check how the evaporator coils are covered with snow/frost. Normally it suppose to be about 100% covered with thin snow. Post the results.
