mehullica
#1 Posted : Sunday, October 28, 2007 10:49:41 AM(UTC)
mehullica
My 6 year old whirlpool washer works fine through all cycles, except when the water drains. There is a high pitched noise as the water is being pumped out. The water does drain out, just really noisy. Is this a water pump issue? Or does the motor have 2 drive ends, one for the agiator side and one for the drain pump side that could be a problem also? Please someone help!--Thanks!!
ApplianceJunk
#2 Posted : Sunday, October 28, 2007 12:04:49 PM(UTC)
ApplianceJunk
Yep,
Check to see if you have something caught in the pump.
This video will show you how.
Video: How To Replace a Water Pump On A Whirlpool Made Direct Drive Washer
