rvkmk1
#1 Posted : Tuesday, July 26, 2011 11:29:49 AM(UTC)
rvkmk1
Washer does everything right but now is only letting hot water in rinse cycle instead of cold water. (All rinse cycles should only be cold according to the diagrams and dials on the control board on the machine.)
Jeff / APP Team
#2 Posted : Tuesday, July 26, 2011 11:42:32 AM(UTC)
Jeff / APP Team
Hello rvkmk1. Check and make sure the water hoses are not reversed going to the water valve. If they are correct, then the temperature switch is bad. The switch has been discontinued for this model. Hope this helps.
Part number: AP3096268
