good9682
#1 Posted : Tuesday, December 9, 2008 1:13:12 PM(UTC)
good9682
The dishwasher will not start in any mode. You can hit cancel/drain and it will switch to drain and the motor runs but that is it. Is the control panel bad or is there something else I can check?
#2 Posted : Tuesday, December 9, 2008 2:01:34 PM(UTC)
Here is your parts breakdown
Model DU915PWPB2
Here is a tech sheet
http://www.servicematters.com/docs/wiring/wiring_main.htm
Unit has a thermal fuse Item 4 in "Frame and console parts" section but the drain works so it is probably OK
When you say it does not start do you hear anything or does absolutely nothing happen.
If nothing
Remove the inner liner from the door
Check that everything looks OK and it is dry
Remove the plugs from the control board and reconnect them
Remove the ribbon cable that comes from the control panel to the control.
Check it for hairline cracks across the tracks a magnifying glass helps here
If it is the type that does not have a connector on the end (just insulation is missing) clean the contact tracks with a pencil eraser. Do not use an ink eraser it is too abrasive.
Not a bad idea to also clean the connector on the control board itself. You can use electronics cleaner or isopropyl alcohol and a toothbrush, just be gentle. Do not plug it back together till all the solvent has evaporated.
Then give it a try.
good9682
#3 Posted : Tuesday, December 9, 2008 2:18:26 PM(UTC)
good9682
You can set any mode function and it all looks ok, you press start and nothing happens, no sounds, you don't hear anything. I press cancel/drain and the motor starts to drain, press cancel again and it shuts off.
#4 Posted : Tuesday, December 9, 2008 5:24:31 PM(UTC)
My earlier post may still apply perhaps it is just the start key connection that is bad
Speaking on bad I screwed up the link to your tech sheet
Here it is
https://www.servicematters.com/d...0Sheet%20-%208535431.pdf
good9682
#5 Posted : Wednesday, December 10, 2008 11:48:40 AM(UTC)
good9682
denman, thanks a lot, i removed all connections and re-connected, it works fine now
agdi4xx
#6 Posted : Thursday, December 11, 2008 8:27:59 PM(UTC)
agdi4xx
Sound like your control panel is Out.
Dryer cuts on and clicks but will not start (Dryer Repair)
by brandinm 2/10/2024 5:09:13 PM(UTC)
GE Cafe dishwasher will not start (Dishwasher Repair)
by Guest 5/18/2023 11:11:14 PM(UTC)
Maytag Bravos XL Electric Druer will not start (Dryer Repair)
by Guest 4/30/2023 12:48:35 PM(UTC)
My freezer will not start after replacing a bunch of parts. (Refrigerator & Freezer Repair)
by popsynth 9/7/2022 4:22:42 PM(UTC)
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
No lights on panel, will not start (Washer Repair)
by jesus freak 5/5/2022 7:46:25 PM(UTC)
GE Profile PHB920EJES will not startup (Oven Repair (including Ranges and Cooktops))
by successworks 11/26/2021 7:15:43 AM(UTC)
GE GDT635HSJ2SS Will not start (Dishwasher Repair)
by xian67 3/29/2021 12:42:26 PM(UTC)
Samsung Aquajet Top Loader will not start (Washer Repair)
by jonwd73 4/8/2020 9:10:21 AM(UTC)
Maytag MDB8959AWS5 lights on but will not start, clicking sound (Dishwasher Repair)
by beachsideandy 10/15/2019 8:56:47 AM(UTC)
Sensing light illuminates but dryewr will not start (Dryer Repair)
by john skalet 10/9/2019 7:08:28 PM(UTC)
Kitchen aid side by side Fridge will not start (Refrigerator & Freezer Repair)
by good used stuff 4/22/2019 10:35:09 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
Cycles Will Not Start (Washer Repair)
by Alienz8mypopcorn 3/13/2017 12:04:22 PM(UTC)
