I turned my oven on tonight to preheat for lasagna and shortly thereafter it started beeping and an F10 error code was displaying. I noticed that the broil element was on but not the bottom element. When it cooled down I turned it back on to try again and same thing....it was on Bake but only the broil element was working and the F10 error appeared again. Any ideas on what this may be??? Money is really tight right now and we cannot afford a repairman or a new stove! :confused:
Did you resolve your problem?
Yes, it is the clock/timer depending on your model number it ranges from $80-$100 for the part.
