phughes
#1 Posted : Monday, December 8, 2008 9:40:19 AM(UTC)
phughes
dryer wont start but i can hear the timer and the light works
#2 Posted : Monday, December 8, 2008 4:59:00 PM(UTC)
The first thing I would do is remove the rear panel and check the thermal fuse (#7 on the break down diagram) for continuity. Replace the fuse if it's open.
It is recommended by the manufacturer to replace the cycling thermostat (#8 on the break down diagram) in case if the thermal fuse is blown.
Check the exhaust line (inside and outside the dryer) for a clog.
- The part number for the thermal fuse is AP3132867
- The part number for the cycling thermostat is AP3131939
Here are the break down diagrams for the Whirlpool dryer Model LER8857EQ0
