potty
#1 Posted : Thursday, July 21, 2011 3:37:21 PM(UTC)
potty
The dryer is making a squeeling noise. I have taken the rollers of and sanded the post and applied grease also did the same to the idler pulley and replaced the glides, and it still is making the sound just wondering if the pulley goes bad or if it is something else. thanks
#2 Posted : Friday, July 22, 2011 4:34:58 AM(UTC)
Here are your parts.
Sounds like you have replaced or greased most things that are involved with the drum rotation.
Grease is not a great idea in a dryer as it will collect and hold lint but it should have either eliminated or reduced the screech if you had found the correct part.
I would open it up and check for any signs of wear on the drum at the back and the front.
Spin the motor to see if it is OK. It is possible that it's bearings are shot also could be that there is something in the blower scraping as it rotates.
Sometimes the motor bearings will only make a racket when there is tension on them from the belt.
I would also check the endbells on the motor, see below.
http://www.applianceaid.com/drymotor_bad.html
How to repair squeeling noise on dryer motor (Dryer Repair)
by Traveller555 7/11/2014 8:42:34 AM(UTC)
Washer SQUEELS after repair (Washer Repair)
by gawlerj 7/3/2013 5:13:22 PM(UTC)
washer squeels loudly for 10 seconds (Washer Repair)
by coleen 6/4/2012 11:21:42 PM(UTC)
Dryer is Squeeling (Dryer Repair)
by jhalco 5/8/2012 7:17:50 PM(UTC)
Maytag Dryer- making horrible squeaking/squeeling noise (Dryer Repair)
by Phillady1 5/23/2011 6:50:44 AM(UTC)
Washer makes a squeeling noise during the final spin (Washer Repair)
by gradyl 4/25/2011 9:55:13 AM(UTC)
Maytag washer squeels on spin (Washer Repair)
by bridgewater 11/17/2010 12:34:08 AM(UTC)
Motor squeeling like a hampster wheel. (Refrigerator & Freezer Repair)
by Andyd5 11/12/2010 2:23:38 PM(UTC)
Help Me Stop The Squeeling/Screetching (Dryer Repair)
by f8191z 10/2/2010 9:51:29 PM(UTC)
Amana Gas dryer high pitched squeel when running (Dryer Repair)
by fixorbuy 8/7/2010 5:16:09 PM(UTC)
Lots of squeeling when dryer runs (Dryer Repair)
by Bill Kay 7/13/2010 11:27:46 AM(UTC)
Maytag squeels when spinning (Washer Repair)
by rustbelt 2/24/2010 12:19:35 PM(UTC)
Squeeling Dryer (Dryer Repair)
by darla4257 11/19/2009 1:45:21 PM(UTC)
Squeeling noise coming from vent duct (Dryer Repair)
by Chris64 10/22/2009 7:06:29 PM(UTC)
squeels at start of spin cycle (Washer Repair)
by rdean 10/3/2009 10:36:34 AM(UTC)
