Bill Kay
#1 Posted : Tuesday, July 13, 2010 11:27:46 AM(UTC)
Bill Kay
I have a lot of squeeling from around the tub when the dryer is running. Not all the time, but most of the time. I opened the top and couldn't see much from there. How much do I have to take apart to check the bearing and belt guide? Can I take the back off and see what I need to see? Any help would be appreciated, thanks
sidfink43
#2 Posted : Thursday, July 15, 2010 5:42:10 PM(UTC)
sidfink43
You get into this from the front, this service manual will show you how.
http://www.servicematters.com/m...ibrary/docs/16023020.pdf
It's a pretty easy job, even if you have never done it before, and if you clean it out good, replace the rollers, belt and pulley you should be all set.
