Marv Wiehe
#1 Posted : Monday, December 8, 2008 10:21:18 AM(UTC)
Marv Wiehe
I need to order a replacment and I am looking at part # AP2027808: Disc. ele. & Quot; 7".
What's a Quot?
Mine measures about 7 1/2". Is your 7" the same?
Mine has a center heat sensor. Does yours? And do I need it?
Thanks,
Marv
abadfish66
#2 Posted : Monday, December 8, 2008 10:36:31 AM(UTC)
abadfish66
Not sure what Quot is, but that is a GE direct replacement part, the same exact part you would get from GE, Yes, has the center sensor, and yes you need it
libertyappl
#3 Posted : Monday, December 8, 2008 10:39:12 AM(UTC)
libertyappl
This is the part number I pulled up for the mentioned element AP2027820
Nat
abadfish66
#4 Posted : Monday, December 8, 2008 10:40:25 AM(UTC)
abadfish66
That's a different # than the one you posted earlier, which burner do you need, the 7" ?
