I need to order a replacment and I am looking at part # AP2027808: Disc. ele. & Quot; 7".
What's a Quot?
Mine measures about 7 1/2". Is your 7" the same?
Mine has a center heat sensor. Does yours? And do I need it?
Thanks, Marv
Not sure what Quot is, but that is a GE direct replacement part, the same exact part you would get from GE, Yes, has the center sensor, and yes you need it
This is the part number I pulled up for the mentioned element AP2027820
Nat
That's a different # than the one you posted earlier, which burner do you need, the 7" ?
