hider
#1 Posted : Monday, July 18, 2011 9:45:19 AM(UTC)
hider
Washer Starts /fills With Water; However, Same Shuts Off After Approximately 2 Min. And Displays Err Pause. There Is No Numeric Error Code, Just Err. It Will Drain And Spin Sometimes. If I Play With The Door/and Unplug The Machine I Can Get It To Work For A Few Minutes
sidfink43
#2 Posted : Tuesday, July 19, 2011 6:01:04 PM(UTC)
sidfink43
Inside the lower service panel are some tech notes that will show you how to put it into a diagnostic mode and generate error codes. On your model these will be generated as flashing lights.
It sounds like the door lock assembly is bad, that is where I would concentrate. It can also be the wiring between the door lock assembly and the control unit, and if all that checks out the control unit is suspect.
Dishwasher starts then stops (Dishwasher Repair)
by rkoerner 11/29/2018 11:47:14 AM(UTC)
Washer starts then stops (Washer Repair)
by JWCT 10/10/2013 8:18:51 AM(UTC)
DIsh washer starts then stops (Dishwasher Repair)
by mbojar69 10/30/2012 6:52:01 AM(UTC)
Kitchenaid washer starts then stops then restarts (Washer Repair)
by Merv 10/17/2009 8:08:48 AM(UTC)
