2 Pages<12
Jeff / APP Team
#11 Posted : Tuesday, July 19, 2011 4:08:56 AM(UTC)
Jeff / APP Team
Try running the machine in spin cycle with the front panel off and watch the tub to pump hose. If it starts to collapse you will need to remove the inner tub and see if something is loose inside between the inner and outer tub and is covering the hole during spin cycle. Hope this helps.
GE washer spins but won't drain (Washer Repair)
by ndngirl 9/17/2011 8:27:58 AM(UTC)
Washer spins but won't drain (Washer Repair)
by Rae 9/15/2009 11:05:10 AM(UTC)
2 Pages<12
