2 Pages12>
Etera
#1 Posted : Friday, July 15, 2011 11:53:15 AM(UTC)
Etera
My washer recently stopped draining. It spins, but will not drain.
Steps I have taken:
1)Removed the housing
2)Removed the hose from the drum to the pump to see if it was clogged. It is not clogged, I know this because all the water drained out onto my floor just fine.:eek: (i did plan for this somewhat and had moved the machine right next to the drain in the floor).
3)I tested to see if the hose from the pump to the sink was clogged and it is not.
4)I removed the pump. There is nothing visible inside of it, and it spins fine when I turn it by hand.
5)Turned the machine on. The motor and drum spin fine.
6)Checked the belt between the motor and the pump. Nothing immediately jumps out as being wrong with the belt.
I am at a loss for what the problem might be and am open to any advice.
Jeff / APP Team
#2 Posted : Friday, July 15, 2011 12:01:44 PM(UTC)
Jeff / APP Team
Hello Etera. What is the model number of your washer? Thanks.
Model Number Locator
Etera
#3 Posted : Friday, July 15, 2011 12:12:48 PM(UTC)
Etera
Model Number: AA5421W
Jeff / APP Team
#4 Posted : Friday, July 15, 2011 12:35:45 PM(UTC)
Jeff / APP Team
Hello Etera. Remove the pump from the machine. Insert a flat blade screwdriver inside the pump and hold the impeller. Turn the pulley on the bottom of the pump and see if it turns without the impeller moving. If so, you will need to replace the pump assembly, the impeller is striped out. Hope this helps.
Part number: AP4041384
Etera
#5 Posted : Friday, July 15, 2011 12:39:07 PM(UTC)
Etera
I did as instructed and the pully will not spin when the impeller is blocked.
Jeff / APP Team
#6 Posted : Friday, July 15, 2011 12:41:44 PM(UTC)
Jeff / APP Team
Is the drain hose loose inside the drain pipe or is it air tight?
Etera
#7 Posted : Friday, July 15, 2011 12:55:29 PM(UTC)
Etera
The drain hose has always just been tied to, and draining into, the large wash basin in the basement. The washer has been working like that for several years.
Jeff / APP Team
#8 Posted : Friday, July 15, 2011 1:00:36 PM(UTC)
Jeff / APP Team
Check and make sure the belt is not slipping on the pump pulley.
Etera
#9 Posted : Friday, July 15, 2011 1:08:49 PM(UTC)
Etera
Is there an easy way to check that? I am assuming I will have to reinstall the pump first?
Etera
#10 Posted : Friday, July 15, 2011 1:29:04 PM(UTC)
Etera
I reattached the pump. The belt does not appear to be slipping. I can't say if it was slipping before because I didn't check, but I know it isn't slipping now.
GE washer spins but won't drain (Washer Repair)
by ndngirl 9/17/2011 8:27:58 AM(UTC)
Washer spins but won't drain (Washer Repair)
by Rae 9/15/2009 11:05:10 AM(UTC)
2 Pages12>
