ttait
#1 Posted : Sunday, December 7, 2008 7:59:37 AM(UTC)
ttait
My washer is leaking from the bottom of the drum and occasinally smells of burnt rubber.
kayakcrzy
#2 Posted : Monday, December 8, 2008 4:45:24 AM(UTC)
kayakcrzy
UserPostedImage
This is a picture of the mounting stem, and seal kit. If you take the front off the washer, and run a test cycle, and the water leaks out from the washer, right from the center of the tub. Then this will be the problem. Tom ApplianceEducator.com
