pkozi1
#1 Posted : Sunday, October 19, 2008 12:14:52 AM(UTC)
pkozi1
when i push the power button the power doesn't come on. i then remove the front panel and pull the connector out of the cpu. i replace the connector and the power then turns on and the washer functions normally. it might work correctly the next time or not, but eventually i have to do the same thing again. no error codes exist. in doing a diagnostic test everything is normal. any help would be appreciated
:confused:
#2 Posted : Sunday, October 19, 2008 6:51:01 AM(UTC)
I would look for partially seated pins in all the connectors, sometimes they work loose.
pkozi1
#3 Posted : Sunday, October 19, 2008 11:45:12 AM(UTC)
pkozi1
been there, done that..any other suggestions. seems like the controller has to be reset all the time?
totomo
#4 Posted : Saturday, December 6, 2008 11:13:40 PM(UTC)
totomo
I just replaced the user interface, but I am not getting power to the board. Did you find a solution to your problem? I may have the same issue.
