when i push the power button the power doesn't come on. i then remove the front panel and pull the connector out of the cpu. i replace the connector and the power then turns on and the washer functions normally. it might work correctly the next time or not, but eventually i have to do the same thing again. no error codes exist. in doing a diagnostic test everything is normal. any help would be appreciated :confused:
I would look for partially seated pins in all the connectors, sometimes they work loose.
been there, done that..any other suggestions. seems like the controller has to be reset all the time?
I just replaced the user interface, but I am not getting power to the board. Did you find a solution to your problem? I may have the same issue.
