20 Pages«<1516171819>»
Oldrustyranger
#161 Posted : Tuesday, July 12, 2011 4:55:40 PM(UTC)
Oldrustyranger
Just wanted to thank you for the detailed process. checked each item as guided . Replaced thermal fuse and cycling thermostat. Both were bad.
Ordered the parts from ApplianceParts. Had rthem two days later.
Read more: http://forum.appliancepartspros...dryer.html#ixzz1RwTdY1ZM
http://forum.appliancepartspros.com
#162 Posted : Wednesday, July 13, 2011 5:52:31 PM(UTC)
You are welcome. We are glad it's up and running.
jephrey88
#163 Posted : Sunday, July 31, 2011 6:13:22 PM(UTC)
jephrey88
Gene,
I searched for answers, but nothing is coming up with my exact issue. I'm getting the igniter to glow, but after the dryer runs for a few minutes the flame kicks off. If I wait a couple hours I can start it again, but get the same results. Would this have anything to do with my cycling thermostat and/or thermal fuse? I'm guessing the flame sensor still works since I can get a flame most of the time.
I have a Whirlpool LGR5636EQ2 - any help would be MUCH appreciated!!!
Jeff
#164 Posted : Monday, August 1, 2011 12:28:26 PM(UTC)
Jeff,
In order to maintain the proper and constant temperature inside the dryer the flame should cycle ON and OFF.
If the flame does not light any time when the igniter glows then the problem is a bad gas valve coils.
- The coil kit Part number: AP3094251
jephrey88
#165 Posted : Monday, August 1, 2011 12:30:21 PM(UTC)
jephrey88
Thanks for the reply, Gene. I tested the coils and have continuity there. The flame will light occasionally. The thermal fuse, however, had zero continuity. I'm picking one up today.
This is a great forum! Thanks for all your help!
#166 Posted : Monday, August 1, 2011 12:42:38 PM(UTC)
The continuity test does not prove they are good. It is very common issue when the coils start acting up under the heat stress.
If the thermal fuse is bad then the igniter will never glow.
So, my advice is to replace the coils.
jephrey88
#167 Posted : Monday, August 1, 2011 12:53:09 PM(UTC)
jephrey88
Should I ignore the zero continuity on the thermal fuse since I'm getting a flame occasionally and just replace the coils?
Thanks again!
#168 Posted : Monday, August 1, 2011 1:56:49 PM(UTC)
0 Ohms resistance as the continuity test result is good. It means there is continuity. Negative result is everything more than zero.
jephrey88
#169 Posted : Monday, August 1, 2011 2:00:42 PM(UTC)
jephrey88
Coils it is then! Thanks, Gene! You rock!
#170 Posted : Monday, August 1, 2011 2:27:36 PM(UTC)
You are welcome Jeff. I'm glad it was that simple.
Guest (18)
