refrigerator purchased by daughter around 97. in use approximately 8 of those years. i've spent the last couple of days doing research. freezer nor refrig cooling. both fans,in freezer and the one in the back are working. started hearing a clicking sound after we realized that it was no longer cooling. forum said to check start relay and overload. removed component from side of compressor,shook and listen for rattle. not only was there a rattle but there was a burnt smell. once i opened up box to get to relays the inside pieces were broken up and part of the plastic was melted. i 've done some reseach and it seems that i need parts #61003115 and #61003116. however i'm not sure what to do about the box that the components fit in. does it come with the 2 parts. i also saw a part called a terminal cover. is this what i need ? part # 61002138 . the first 2 part look like what i have. once i get my part all i want to do is reconnect the 3 prongs and snap it back on the compressor. please help . thank you.
Originally Posted by: richappy ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) You posted a bad model # hello richappy, thank you for replying. all infor in original post was correct. refrigerator is model HMG61139,admiral designer series, purchased from montgomery wards in 97. i purchased the parts mentioned in the post from a local vendor called **************. parts have been replaced and the box is cooling and freezing beautifully. the majority of post from your website are right on point. again thank you.:)
