paracutin
#1 Posted : Tuesday, July 12, 2011 6:20:06 PM(UTC)
paracutin
Bottom freezer model. Freezes well. Refrigerator temp no lower than 48 degrees.
I removed the panel inside the refer box to expose the evaporator.
Evap was frozen up. The evap fan works fine.
There are two thermistors (yellow wire sensors). One attached to the bottom of the evap, the other in the panel I removed to get to the evap. I checked resistance of each. One was 4.7k ohms, the other 5.0k ohms.
There is a plug with red/black wires. This goes to something that looks sort of like a cylinder with a cone on top. It is sealed in clear plastic and wrapped in soft foam.
There is another plug with red/white wires. This goes to the evap heater and drain tray heater. Evap heater reads 113 ohms. Drain tray heater reads 340 ohms.
Anyone have any ideas as to what is going on? I really need some help!
paracutin
#2 Posted : Wednesday, July 13, 2011 7:29:52 AM(UTC)
paracutin
I should mention that this unit has a separate evap and fan for the fridge and freezer. No damper between them.
I have pics that I will include if I can figure out how to upload them.
New Side by Side mystery - Fridge won't cool enough (Refrigerator & Freezer Repair)
by harold (louisiana) 12/7/2015 1:43:51 PM(UTC)
Fridge won't cool. Freezer ok. (Refrigerator & Freezer Repair)
by bethompson32 7/17/2012 8:42:06 AM(UTC)
Fridge won't cool & freezer isn't cold (Refrigerator & Freezer Repair)
by HTCTX 2/3/2012 12:20:45 PM(UTC)
Amana fridge won't cool, freezer fine (Refrigerator & Freezer Repair)
by b3bilco 4/30/2010 7:56:58 AM(UTC)
Fridge won't cool (Refrigerator & Freezer Repair)
by Wildrat 4/27/2010 11:18:32 AM(UTC)
My Fridge won't cool (Refrigerator & Freezer Repair)
by vxmolina4 10/16/2008 4:17:21 PM(UTC)
Fridgidaire FRS22ZGH freezer works/fridge won't cool (Refrigerator & Freezer Repair)
by WMOYLAN 1/26/2008 4:38:24 AM(UTC)
Freezer works, Fridge won't Cool...fan stops (Refrigerator & Freezer Repair)
by Gamla33 10/7/2007 6:41:32 AM(UTC)
