Wildrat
#1 Posted : Tuesday, April 27, 2010 11:18:32 AM(UTC)
Wildrat
Views messages in topic : 3
My fridge stopped cooling. I checked everything out and electrically it's fine. I discovered a leak at the suction line where it connects to the compressor. I installed a piercing valve and it has no refrigerant. I turned the fridge on and it's still pulling into a vacuum so the compressor is likely good.
I am a HVAC fella and have never serviced a fridge. I am going to repair the leak, that should be no big deal. I have the R-134A and my gauges, etc..
I just need to know what my suction pressure should be approx.. I know on a car with 134a it's around 40-45 psi but that's a car. So any help will be appreciated.
Mark
Wildrat
#2 Posted : Tuesday, April 27, 2010 12:00:40 PM(UTC)
Wildrat
Leak soldered, vac pump plugging away. I hope a two stage vac pump is not to much for the fridge. I sure hope someone replies with an answer to my other question soon.
Wildrat
#3 Posted : Tuesday, April 27, 2010 2:50:10 PM(UTC)
Wildrat
well I've got it charged. I am adjusting the charge now to a ball park temp. So far I have about 49°F. SO I have some adjusting left to do. I think I will go check it now.
New Side by Side mystery - Fridge won't cool enough (Refrigerator & Freezer Repair)
by harold (louisiana) 12/7/2015 1:43:51 PM(UTC)
Fridge won't cool. Freezer ok. (Refrigerator & Freezer Repair)
by bethompson32 7/17/2012 8:42:06 AM(UTC)
Fridge won't cool & freezer isn't cold (Refrigerator & Freezer Repair)
by HTCTX 2/3/2012 12:20:45 PM(UTC)
Fridge Won't cool (Refrigerator & Freezer Repair)
by paracutin 7/12/2011 6:20:06 PM(UTC)
Amana fridge won't cool, freezer fine (Refrigerator & Freezer Repair)
by b3bilco 4/30/2010 7:56:58 AM(UTC)
My Fridge won't cool (Refrigerator & Freezer Repair)
by vxmolina4 10/16/2008 4:17:21 PM(UTC)
Fridgidaire FRS22ZGH freezer works/fridge won't cool (Refrigerator & Freezer Repair)
by WMOYLAN 1/26/2008 4:38:24 AM(UTC)
Freezer works, Fridge won't Cool...fan stops (Refrigerator & Freezer Repair)
by Gamla33 10/7/2007 6:41:32 AM(UTC)
