2 Pages12>
ALASKACOLE
#1 Posted : Friday, December 5, 2008 11:55:35 AM(UTC)
ALASKACOLE
Hello Cyber Appliance World - Exactly 13 months after purchase my new GE Profile JE2160BF microwave was totally dead - no power, lights, or anything. Since I knew the warranty was just up and GE's reputation for doing warranty work, I opened it up and replaced the fuse. Viola! Everything worked fine again. I left it open and used it for 5 days before buttoning up and reinstalling with trim kit into wall cavity. Of course, it quit working again. This time all of the electoronic timer and 1-touch button functions are working, and the oven light comes on. I can hear the relay click when I hit 'start' and the timer stars counting down, but the turntable does not work and the oven does not heat. I have read most of the related forum threads and would assume the magnetron is bad. What has confused me is that the turntable does not work either. Is there in interconnect of some sort that if the magnetron is bad it shuts down the turntable motor, or could I have something else wrong here. I am a layman who likes to fix things myself, but do not have much experience with electrical diagnosis. If I need to test any of the components or circuits, can you please treat me like a 5 year old in describing how to use my multi-tester as far as what to set it for and what I am looking for. Lastly, I keep hearing that you should replace the HV diode at the same time as the magnetron. Is that correct, and can you tell me where it is located? I have the electrical diagnosis paper that was inside the microwave, but it is not clear on the physical location of the diode, just lists it in the circuit diagram. Thanks for your time and help.
abadfish66
#2 Posted : Friday, December 5, 2008 12:08:13 PM(UTC)
abadfish66
Groups ready for retrieval: Senior Expert
You have been a member since:: 5/28/2008(UTC)
Views messages in topic : 1,620
Your problem is Not the magnetron tube. There is always a reason a fuse blows, and in this case I suspect the monitor switch ( on the latch bracket) A bad monitor switch will blow a fuse, it will also not allow the turntable or mag tube to come on.
ALASKACOLE
#3 Posted : Friday, December 5, 2008 1:20:45 PM(UTC)
ALASKACOLE
Hello 'Bad Fish' - I was hoping to hear from you. You always seem to zero right in on a problem and give good advice. Plus, based on your avatar, I think you must be a fellow long suffering Seahawk fan!
I hope it is good news that it is a switch problem and not my magnetron. I am not able to find a 'monitor switch' or 'latch bracket' on either the APP parts list or the GE website parts list. Are you able to give me the part numbers on these items. I find a number of switches listed and a latch slider. Here is a link to the GE parts diagram - could you tell me if the items you mentioned are on there and what the corresponding diagram is that I can match up the to GE parts list.
GE Parts Diagram: http://genet.geappliances.com/I...0018600/00018617.p01.pdf
Thanks again for your help.
Cole
abadfish66
#4 Posted : Friday, December 5, 2008 1:50:52 PM(UTC)
abadfish66
Washington State just passed a law making assisted suicide legal.....Seahawk fans are the biggest supporters of this new law :)
Anyway, it is item# 2010 on the diagram, part# wb24x824.... It is gonna be the switch (usually in the middle) on the latch bracket. The latch bracket is what holds the door switches. It will be the switch that doesn't look like the other switches.
abadfish66
#5 Posted : Friday, December 5, 2008 1:52:02 PM(UTC)
abadfish66
Oh yea....Go Hawks!!!!!!! and get rid of that damn General Manager
ALASKACOLE
#6 Posted : Friday, December 5, 2008 2:23:11 PM(UTC)
ALASKACOLE
Yeah, I don't think the Hawks are going to feel the love from NE this Sunday. At least it is a home game and maybe the 12th man will break a record for causing false starts!
Is there a way, or do you think I should, test that switch, or do you think it is necessary? Sounds like that is the likely culprit. It is only $8 on the GE website, so cheap enough to put one in and see.
abadfish66
#7 Posted : Friday, December 5, 2008 2:49:28 PM(UTC)
abadfish66
Here you go :)
Monitor Door Switch Test:
1. Disconnect power, open control panel, and discharge capacitor.
2. Remove one monitor switch lead to isolate switch. Check continuity of switch with door
open and door closed:
Door Closed – Infinite Ohms
Door Open – 0 Ohms
3. Reconnect switch wiring.
4. Check fuse (15 or 20 Amp) for continuity and proper size. If needed replace fuse. 15 Amp
use WB27X0007. 20 Amp use WB27X3910.
5. Test Circuit Operation:
A) Connect temporary jumper across relay contact and primary switch to simulate shorted
switch contacts. Locate convenient connections in circuit to be certain COM and N. O.
terminals are used.
B) Connect Ohmmeter (Low Scale) across the two line terminals of appliance power cord.
Continuity must show:
Door Closed – Some Ohms
Door Open – 0 Ohms
C) Remove 20 Amp. Fuse – Circuit must open (Infinite Ohms). If not, check wiring of
monitor an interlock circuits.
D) WARNING! After test, remove temporary jumper leads from interlocks and relay.
Reconnect monitor switch leads. Replace fuse.
E) Replacement of any parts of monitor circuit requires repeating this entire test procedure
WARNING! When (15 or 20 Amp) fuse is blown due to operation of the monitor
switch, the monitor switch must be replaced. Also replace relays and/or
interlock switches when continuity check shows contacts shorted.
ALASKACOLE
#8 Posted : Friday, December 5, 2008 5:56:14 PM(UTC)
ALASKACOLE
Thanks, Bad Fish. I am in deep water here but your instructions are pretty clear and I think I can dog paddle through it. However, if I just get a new switch and swap it out (assuming it was bad), is it likely to just start working, or would I still need to be checking those circuits and continuity for something else wrong? I am good with instructions 1-5, but not so good on A-E. Sorry, don't mean to be a pain and truly appreciate all you are doing for me. If I start sinking, I will send you a note to abadfish66@cox.net to keep from tying up this forum, if you do not mind.l
abadfish66
#9 Posted : Friday, December 5, 2008 6:42:16 PM(UTC)
abadfish66
I don't mind :) 1-5 is really all you need to do, the rest is just, well, the rest. I am with about 99% certainty based on the evidence given, that in the previous statements brought forth today that the monitor switch is the guilty party, if not we'll proceed further :)
ALASKACOLE
#10 Posted : Thursday, January 29, 2009 6:39:12 PM(UTC)
ALASKACOLE
I replaced the monitor switch on the latch bracket and nothing changed. Can you suggest my next step? Something made the original fuse blow, so am I back to a new magnetron?
Guest (4)
2 Pages12>
