elizaine729
#1 Posted : Sunday, July 10, 2011 9:12:22 AM(UTC)
elizaine729
I washed 2 loads of laundry yesterday. On the third load after the wash cycle the washer filled up then hasn't moved since. I had it on the Large load setting and it filled to XLarge but then nothing. It will not agitate, will not drain, and will not spin.
Any suggestions on what to do or check?
I have tried other settings and have tried to unplug it.
sidfink43
#2 Posted : Monday, July 11, 2011 5:58:17 PM(UTC)
sidfink43
Sounds like the classic lid switch problem. Check it out or bypass it and if it works, replace the lid switch and you are all set.
elizaine729
#3 Posted : Tuesday, July 12, 2011 6:57:52 AM(UTC)
elizaine729
Thanks so much sidfink43 for replying I appreciate it! Thanks to the internet and some research it all pointed to the lid switch as well and we have one on order from the local appliance store picking it up today.
Hope it works!
thanks again!
sidfink43
#4 Posted : Tuesday, July 12, 2011 9:57:59 AM(UTC)
sidfink43
Good, let us know how it turns out.
Dead Washer (Washer Repair)
by MMMM 1/15/2016 10:51:07 AM(UTC)
by CNELSONCOOPER 11/28/2012 11:28:40 AM(UTC)
Dead washer (Washer Repair)
by Matthewryan 7/26/2012 6:39:30 PM(UTC)
by PepeCo 2/8/2012 7:13:27 PM(UTC)
dead washer (Washer Repair)
by daddy1 10/29/2010 5:42:19 AM(UTC)
