lambchop68
#1 Posted : Monday, July 11, 2011 4:04:24 PM(UTC)
lambchop68
When the button is pushed to turn on the dryer, the button clicks but the motor does not spin.
I have checked the switch for the door and it does kick out the button when the door is opened so the door switch seems to be OK.
I do have an ohm meter but not exactly sure how to use it nor what my next thing would be to check.
Any help would be greatly appreciated
#2 Posted : Monday, July 11, 2011 11:30:49 PM(UTC)
Replacement parts for WHIRLPOOL LER8648LG0 RESIDENTIAL DRYER | AppliancePartsPros.com
I a assuming that the motor does not make any noise.
The most common cause would be the thermal fuse is blown (Item 7 in Section 3). It is in the motor circuit.
Unplug the unit and check the fuse with a meter should be 0 ohms.
If it is blown be sure to clean/check your vent system and blower wheel as they are the most common cause of this fuse blowing.
Replace it ASAP as it is a critical safety device which prevents lint fires which can turn into house fires.
Here is some info on meter usage.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
