eatonr
#1 Posted : Saturday, July 9, 2011 7:16:07 PM(UTC)
eatonr
My dishwasher would not turn on last week,so took front panel off and looked at components checked all conections everything looked good so i thought i would put it back together and get a service manual.After i put it back together i tryed the power button again and the lights came on and everything was working again.But it ran for a week and now it is dead again.I have 120 volts to switch,not sure switch is working properley because there are 3 normaly open contacts on switch when i check continuity 2 swithes have it but the third set has continuitiy when i hold the switch down it seems it never latches.Their still should be Lights on control module when i hold swith down but no lights come on.Could the control module be bad as well as off/on switch.Really need a troubleshooting manual.
eatonr
#2 Posted : Saturday, July 9, 2011 7:18:36 PM(UTC)
eatonr
Originally Posted by: eatonr Go to Quoted Post
My dishwasher would not turn on last week,so took front panel off and looked at components checked all conections everything looked good so i thought i would put it back together and get a service manual.After i put it back together i tryed the power button again and the lights came on and everything was working again.But it ran for a week and now it is dead again.I have 120 volts to switch,not sure switch is working properley because there are 3 normaly open contacts on switch when i check continuity 2 swithes have it but the third set has continuitiy when i hold the switch down it seems it never latches.Their still should be Lights on control module when i hold swith down but no lights come on.Could the control module be bad as well as off/on switch.Really need a troubleshooting manual Can anyone help? Its a Bosch SHX46b05uc/14.
mwilsonpa
#3 Posted : Tuesday, August 23, 2011 5:35:13 PM(UTC)
mwilsonpa
I am having the same problem no lights come on at all. It is a SHU 5312UC model. anyone have thoughts on this. the breaker is not kicked. Should I take off the front cover and test everything, I have read the manuel, just dont know where to start>
No lights at all (Washer Repair)
by gglenday 10/10/2011 2:33:34 PM(UTC)
