misterfixall
#1 Posted : Thursday, December 4, 2008 12:27:02 PM(UTC)
misterfixall
hi .i have a ge F/L washer the spring that hold the boot in place at drum has come off. the boot appears ok. i do not see a way of installing this spring without taking apart the whole front assembly ,which is a huge pain .this is an older style ,any info .thanks the spring # is 131277300
abadfish66
#2 Posted : Thursday, December 4, 2008 12:31:14 PM(UTC)
abadfish66
You don't need to take apart the front assy, but you do need to remove the boot from the front door section to do this. When you have the front boot off, you will need 8 hand to reinstall the spring :) When the front boot is ordered, it comes with rubber wedges. These wedges are used to hold the spring while you work it around. You'll see what I'm talking about when you start putting the spring back on.
misterfixall
#3 Posted : Thursday, December 4, 2008 2:36:03 PM(UTC)
misterfixall
hi ,when you say 8 hand ,do you mean a hand , like some one to assist me? does this boot come with instructions , as how the wedges are used?
abadfish66
#4 Posted : Thursday, December 4, 2008 3:12:50 PM(UTC)
abadfish66
The boot does come with instructions, I was making a joke, I meant 8 hands, because you need to hold the spring in like 4 places to keep it from coming out while you try to get it around. That is what the wedges are for, and the wedges do come with the boot also a new spring.
Guest (4)
