GaryM.
#1 Posted : Thursday, December 4, 2008 3:01:26 AM(UTC)
GaryM.
My washer squeals/groans when it's in a spin cycle. I don't have a repair manual, but I suspect it to be a bearing. Any ideas?
GaryM.
kayakcrzy
#2 Posted : Thursday, December 4, 2008 4:56:31 AM(UTC)
kayakcrzy
It could be a bearing, it could be a belt, and it could be a pump. Take the front off, and see if you can located the noise. Tom ApplianceEducator.com
GaryM.
#3 Posted : Thursday, December 4, 2008 8:42:38 AM(UTC)
GaryM.
Thanks Tom, will do and let you know...
kayakcrzy
#4 Posted : Thursday, December 4, 2008 11:53:41 AM(UTC)
kayakcrzy
Ok. Let me know. Tom
GaryM.
#5 Posted : Monday, December 15, 2008 11:59:05 PM(UTC)
GaryM.
The noise appears to be in the area of the belt. When I rotated the belt by hand to inspect it, I noticed that it was cut almost all the way through. I suspect that this is the culprit. I also saw the bearing on the bottom, sprayed some BREAKFREE on it, then realized that that was a sealed bearing and the lubricant would have no affect on it. How do I get at the belt, and how do I change it?
kayakcrzy
#6 Posted : Tuesday, December 16, 2008 3:12:55 AM(UTC)
kayakcrzy
Gary, the best way to do mthis is to take the 2 screws out that hold the whole motor, and pump assembly out, and then take off the belt, and remove the wiring harness from the motor, and then remove the whole assembly from the washer. Then remove the pump, and then the belt. Then reverse the process. Tom ApplianceEducator.com
GaryM.
#7 Posted : Saturday, December 27, 2008 11:57:20 PM(UTC)
GaryM.
I'll give it a shot this weekend, as the belt is in really bad shape.
Guest (4)
washer squeals when washing (Washer Repair)
by jonellbrandi 10/16/2012 3:11:45 PM(UTC)
Frigidaire washer squeals and leaks (Washer Repair)
by ponderoni 4/5/2012 3:14:50 PM(UTC)
washer squeals on heavy duty setting (Washer Repair)
by dbgtrek 4/25/2010 4:02:24 PM(UTC)
Amana washer squeals on spin (Washer Repair)
by 1dlee54 1/25/2010 5:08:50 PM(UTC)
Whirlpool washer squeals on spin cycle (Washer Repair)
by 330racing 1/24/2010 8:25:45 AM(UTC)
Amana clothes washer squeals and now leaks (Washer Repair)
by SZoerb 4/15/2008 1:19:39 PM(UTC)
