simpletemple
#1 Posted : Wednesday, December 3, 2008 9:03:51 PM(UTC)
simpletemple
Need A Picture Of Wiring Think Thermistor Wires Reversed
#2 Posted : Thursday, December 4, 2008 2:42:13 AM(UTC)
Here it is
https://www.servicematters.com/d...0Sheet%20-%202318069.pdf
And another one which has the diagnostics in it
https://www.servicematters.com/d...0Sheet%20-%202316566.pdf
Usually the polarity of a thermistor makes no difference but this is an appliance company so who knows if what they call a thermistor is actually a thermistor.
As a example for as long as I remember an unwritten rule is: Do not use "o" in Model Numbers, only zeros are used. Also a "Q" is not used as it can be confused with a 0.
Your actual model number is KSSo42QTX00
Looks like Kitchen Aide is making a concerted effort to confuse customers.
Next they will have 1's and I's in their numbers.
simpletemple
#3 Posted : Thursday, December 4, 2008 4:02:08 AM(UTC)
simpletemple
thanks for info :) when i do service diagnostic the freezer thermistor do not do all the sequeces and the same for refrigerator thermistor if i replace them will the unit start cooling.
#4 Posted : Thursday, December 4, 2008 6:38:09 AM(UTC)
I would doubt that this will fix the unit, unless both gave an open or a short reading (error code). Even then I would be suspicious since it is unlikely that both would go at the same time.
http://www.applianceaid.com/frig.html
Perhaps the above will help you diagnose the problem.
GE bottom freezer model #: PFE28KBLTS not cooling well and no ice (Refrigerator & Freezer Repair)
by Danny1976 6/7/2024 12:43:43 PM(UTC)
GE bottom freezer not cooling well and no ice (Refrigerator & Freezer Repair)
by Guest 6/7/2024 7:31:51 AM(UTC)
Kenmore 106.74203402 fridge/freezer not cooling (Refrigerator & Freezer Repair)
by ryancg 5/26/2024 7:58:26 PM(UTC)
Electrolux fridge compartment not cooling, freezer is cold (Refrigerator & Freezer Repair)
by Minthook 4/22/2024 8:17:01 AM(UTC)
kenmore/lg fridge not cooling (Refrigerator & Freezer Repair)
by rleescott 4/16/2024 4:52:09 AM(UTC)
Monogram side-by-side not cooling - Ice builds up on Evaporator Fan (Refrigerator & Freezer Repair)
by 95ireland 3/11/2024 6:22:51 PM(UTC)
Mabe MBC12GAZASS Not Cooling (Refrigerator & Freezer Repair)
by MKDrepair 2/5/2024 5:57:08 AM(UTC)
GE GSS23QSTA not cooling after power outage (Refrigerator & Freezer Repair)
by sfarid123 12/19/2023 7:39:47 AM(UTC)
LG Refrigerator not cooling; compressor clicking. (Refrigerator & Freezer Repair)
by pmrowley 11/8/2023 7:07:53 AM(UTC)
Ge Monogram Integrated Top/Bottom Not Cooling ZICP360NXLH (Refrigerator & Freezer Repair)
by grundyv2 10/7/2023 12:48:51 PM(UTC)
GE botom freezer not cooling (Refrigerator & Freezer Repair)
by Dieselista 10/6/2023 5:39:30 PM(UTC)
Whirlpool WRV986FDEM00 is not cooling (Refrigerator & Freezer Repair)
by Find a fix 9/23/2023 4:03:34 AM(UTC)
Jenn-air refrigerator not cooling (Refrigerator & Freezer Repair)
by pke 9/20/2023 4:18:40 PM(UTC)
Samsung family hub freezer not cooling (Refrigerator & Freezer Repair)
by foster1447 8/20/2023 2:36:12 PM(UTC)
Whirlpool Refrigerator cooling intermittently or not cooling at all (Refrigerator & Freezer Repair)
by lsitnj 8/12/2023 3:39:26 PM(UTC)
