fkukla
#1 Posted : Tuesday, December 2, 2008 9:14:06 AM(UTC)
fkukla
My 'valued' Whirlpool washer just stopped working yesterday. 12 1 08... IE the water will fill, but when I advance any part of the DIAL control buttons & PULL up to start, it just buzzes...please advise QUICKLY need to keep WASHING...thank you:mad: :confused:
#2 Posted : Wednesday, December 3, 2008 2:19:41 PM(UTC)
Originally Posted by: fkukla Go to Quoted Post
...it just buzzes...
Where it's coming from: the motor or the control panel?
fkukla
#3 Posted : Wednesday, December 3, 2008 4:29:18 PM(UTC)
fkukla
Thanks so much for writing. Just checked, the hum is coming from the motor...I can FILL with water, but nothing else works on advancing the dials....cannot DRAIN either. Just the hum in the motor...agitator does not work either. Your HELP is surely appreciated! fkukla
SublimeMasterJW
#4 Posted : Wednesday, December 3, 2008 5:03:15 PM(UTC)
SublimeMasterJW
pump locked up
fkukla
#5 Posted : Wednesday, December 3, 2008 5:44:59 PM(UTC)
fkukla
Originally Posted by: SublimeMasterJW Go to Quoted Post
pump locked up
Thank you!....going to check on it in the am....will let you know if your
diagnosis was correct....thanks again.
