AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Stopped COLD while running,Control knobs just BUZZ
My 'valued' Whirlpool washer just stopped working yesterday. 12 1 08... IE the water will fill, but when I advance any part of the DIAL control buttons & PULL up to start, it just buzzes...please advise QUICKLY need to keep WASHING...thank you:mad: :confused:
Originally Posted by: fkukla ...it just buzzes... Where it's coming from: the motor or the control panel? Gene.
Originally Posted by: Gene Where it's coming from: the motor or the control panel?
Gene. Gene Thanks so much for writing. Just checked, the hum is coming from the motor...I can FILL with water, but nothing else works on advancing the dials....cannot DRAIN either. Just the hum in the motor...agitator does not work either. Your HELP is surely appreciated! fkukla
Originally Posted by: SublimeMasterJW pump locked up Thank you!....going to check on it in the am....will let you know if your diagnosis was correct....thanks again.
Washer Repair
