Yes, I Checked Coupler Between Motor And Pump And Its Fine. Its Just The Bottom Agitator Agitates Back N Forth Whn Washing But When Ever The Tub Goes In Spin The Bottom Agitator Will Not Spin With The Tub Causing Clothes To Wrap Around Agitator And You Have To Stop It And Move Clothes To Side Of Tub To Get Them Away From Agitator To Finish. And Thats Only Washing A Small Load.
Originally Posted by: libertyappl Did you check the coupler between the motor and the pump?
Nat coupler is ok! the bottom agitator agitates but will not spin in mode when tub has to spin!
Anybody Have Any Suggestions On What The Problem Could Be? Could It Be Something In The Transmission Or Clutch Causing The Bottom Agitator Not To Spin With The Tub When Its Suppose Too??????
Souns like the basket drive maybe messed up.
nat
What Exactly Is The Basket Drive? Is that like the drive block! I have been tryn to see where it exactly is at in the washer??
Go to searspartsdirect website and you can see a breakdwon of your machine.
Nat
