sandye
#1 Posted : Saturday, July 2, 2011 11:25:22 AM(UTC)
sandye
I am pretty sure a(or two) small pea gravel size rock(s) got in with my laundry. I was washing the items two times and the washer did drain once. The agitator does work but makes a grinding noise. I tried to drain/spin and also got the grinding noise. I am wanting to remove the agitator to see if I can retrieve the rock. I printed the agitator, basket and tub parts schematic. Does the lid(#1) just pop off.
I have successfully repaired this(my husband actually does the repair) machine three other times with online help.
Can you help me now? I would like to make this machine(combo washer dryer) last a little longer.
sidfink43
#2 Posted : Sunday, July 3, 2011 11:50:11 AM(UTC)
sidfink43
The cap will pry off, then there should be another plastic cap under that and then a 7/16" bolt which will come out. The agitator can now be lifted out of the machine.
Guest (4)
