Exhaust Fan hums, replaced Exhaust Fan Motor same thing happened, Exhaust Fan doesn't work, what should I do now? I've replaced the clock part #71001799:cool:
Originally Posted by: Annies  Exhaust Fan hums, replaced Exhaust Fan Motor same thing happened, Exhaust Fan doesn't work, what should I do now? I've replaced the clock part #71001799.
Originally Posted by: Annies  Originally Posted by: Annies  Exhaust Fan hums, replaced Exhaust Fan Motor same thing happened, Exhaust Fan doesn't work, what should I do now? I've replaced the clock part #71001799 in 2009 because the Fan wouldn't shut off. I've replaced control panel in 2010.
