Hello! The other day it stopped working in the middle of roasting a turkey. My broiler still works, in fact even if I only turn the temp guage up to 300. I was not using the timed-bake feature...I never have. What's your opinion on the most likely cause & will there be a part available to get it going again? Thanks. Johnj1020
The model number posted does not come up please verify the number off the unit itself.
Nat
The model # came right off the aluminum plate under the top cover for the burners. The serial # of my unit is 3L60429, if that helps any. J
This is a substitute round ignitor AP2014008 or WB2X9154 if you can find one locally.
Nat
