johnj1020
#1 Posted : Tuesday, December 2, 2008 10:08:18 AM(UTC)
johnj1020
Hello! The other day it stopped working in the middle of roasting a turkey. My broiler still works, in fact even if I only turn the temp guage up to 300. I was not using the timed-bake feature...I never have. What's your opinion on the most likely cause & will there be a part available to get it going again? Thanks. Johnj1020
libertyappl
#2 Posted : Tuesday, December 2, 2008 12:07:55 PM(UTC)
libertyappl
The model number posted does not come up please verify the number off the unit itself.
Nat
johnj1020
#3 Posted : Tuesday, December 2, 2008 12:40:56 PM(UTC)
johnj1020
The model # came right off the aluminum plate under the top cover for the burners. The serial # of my unit is 3L60429, if that helps any. J
libertyappl
#4 Posted : Tuesday, December 2, 2008 12:54:10 PM(UTC)
libertyappl
This is a substitute round ignitor AP2014008 or WB2X9154 if you can find one locally.
Nat
Guest (4)
