Tony Norris
#1 Posted : Wednesday, June 29, 2011 5:31:05 PM(UTC)
Tony Norris
have refrig TLI22KW, P7803230WW
it stopped cooling, found overload burnt, ordered #1952715, run capacitor and overload & relay assembly.
Installed overload only - plugged in and hear pops(like a loud relay opening or closing a few seconds apart. attempted to then change relay(below it) but old one has 3 wires(2 on one connector) and the new one only has one avail lug instead of 2.
what were pops? what am i not seeing?
#2 Posted : Thursday, June 30, 2011 1:50:48 AM(UTC)
You will need a meter to install parts. The correct part # is shown on this site, but not in stock, might not be available, just call this site.
The pop you heard might be the compressor winding blowing open if you connected things wrong. Should check windings with a meter before ordering parts.
