janick
#1 Posted : Wednesday, June 29, 2011 1:19:29 PM(UTC)
janick
The top two washer racks have no water dispersing while the bottom does. I took the wash assembly apart and there is nothing pluging it. The bottom washer is working and it connects to the top washer. I know there is no water coming out cause i set the washer rack in a fixed position and turn dishwasher on, in rinse cycle. After i heard the water cycle start i opened the door and the upper washer was still in the same position. Maybe the pressure is not enough? Any help would be great.
#2 Posted : Wednesday, June 29, 2011 4:47:32 PM(UTC)
Janick,
The first thing I would do is check the chopper (#6 on the diagram).
You can find more useful information in one of our previous threads: http://forum.appliancepartspros...hirlpool-dishwasher.html
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KUDS02FRSS0 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
janick
#3 Posted : Wednesday, June 29, 2011 6:03:53 PM(UTC)
janick
Janick,
Thanks Gene - how do i get to the chopper. I took everything off and im at #4 in the diagram (looking at sump housing). Do i need to do undereath the dishwasher. I think i'm missing a step
#4 Posted : Thursday, June 30, 2011 12:17:24 PM(UTC)
Just click on the link from the previous reply for instructions.
janick
#5 Posted : Thursday, June 30, 2011 1:07:13 PM(UTC)
janick
Believe it or not i did. :) Could you please tell me if the chopper is on the sum housing (#4) or is it in the accumulator assembly (#1). For some reason i can't find the protector (#8) therefor cany find the chopper. I'm having problems finding it even while I'm looking at the diagram
#6 Posted : Thursday, June 30, 2011 1:47:47 PM(UTC)
It is inside the sump housing under the accumulator assembly. The accumulator assembly has to be removed.
Guest (5)
