gobtool
#1 Posted : Tuesday, December 2, 2008 8:57:09 AM(UTC)
gobtool
I need a wiring diagram for a gsc30cvb and a similar range the uses a 35-00-571 or 486752 (same part I think) control. If I can't get a replacement or repair from C G Industries (waiting for reply) I'm going to try to use this later control with modifications to control panel plate and modifying and extending the wiring as the relay board is on clock/disply. I'm familar with
electronics and my son is an electronics engineer so it should be possible and safe even if not recommended. Thanks for any info and help. My e-mail is gobtool@aol.com if you would rather send a private message.
libertyappl
#2 Posted : Tuesday, December 2, 2008 9:04:22 AM(UTC)
libertyappl
I don't know if this will help, but....
Part Details - BOSCH Kit - erc iii control (30"rng), part number: 486752
Both of those part numbers listed come with installation instructions. But Gene usually pops on in the afternoons, so He will see your post :)
Nat
gobtool
#3 Posted : Wednesday, December 3, 2008 7:36:46 AM(UTC)
gobtool
If I could get the wiring diagrams I could tell if using a newer board would be possible or fesible. I am considering all options instead of replacing. I don't have to have all functions. Thanks again for any help. I forgot to put the brand in the heading. Thermador for anyone doing a search.
Admin / APP Team
#4 Posted : Wednesday, December 3, 2008 10:01:41 AM(UTC)
Admin / APP Team
Rank: Administration
I've checked all my resources and so far no luck on the wiring diagram for this model, sorry. I'll keep looking.
Servicer
#5 Posted : Saturday, December 20, 2008 5:24:30 AM(UTC)
Servicer
This should help..
File Attachment(s):
ESC_GSC_Service Manual.pdf (1,758kb) downloaded 37 time(s).
gobtool
#6 Posted : Tuesday, December 23, 2008 8:26:09 AM(UTC)
gobtool
Just wanted to say thanks to everyone for all the help. C G Industries repaired my oven control/display and relay board and got it back to me very quickly. Everything is working fine now. Thanks again.
Guest (6)
