Excessive vibration when in the spin cycle. I must constantly rebalance load. I opened the front of the washer and checked springs,there OK. Did find a white powder under tub, a very fine dust.
This Ring is most likely your problem. It is located aon the base below the tub. nat
Thanks for the fast repair assessment. I have ordered the friction ring, can you give me some info on the replacement of this part, service manual info?
Thank you
I had to remove the front and top of washer, lean top against the wall. Removed pump inlet and outlet hoses. I made a hook with handle to remove the springs. I lifted the tub and my wife slide in the new friction ring. Vacuumed the dust from old ring, reassembled washer. It works OK now. Thanks again.
Glad you were able to fix it!!! Nat
