phirsch
#1 Posted : Saturday, November 22, 2008 8:10:28 AM(UTC)
phirsch
Excessive vibration when in the spin cycle. I must constantly rebalance load.
I opened the front of the washer and checked springs,there OK. Did find a white powder under tub, a very fine dust.
libertyappl
#2 Posted : Saturday, November 22, 2008 8:23:02 AM(UTC)
libertyappl
This Ring is most likely your problem. It is located aon the base below the tub.
nat
phirsch
#3 Posted : Sunday, November 23, 2008 5:48:02 AM(UTC)
phirsch
Thanks for the fast repair assessment. I have ordered the friction ring, can you give me some info on the replacement of this part, service manual info?
Thank you
phirsch
#4 Posted : Monday, December 1, 2008 7:01:15 AM(UTC)
phirsch
I had to remove the front and top of washer, lean top against the wall. Removed pump inlet and outlet hoses. I made a hook with handle to remove the springs. I lifted the tub and my wife slide in the new friction ring. Vacuumed the dust from old ring, reassembled washer.
It works OK now.
Thanks again.
libertyappl
#5 Posted : Tuesday, December 2, 2008 8:14:23 AM(UTC)
libertyappl
Glad you were able to fix it!!!
Nat
