vns
#1 Posted : Thursday, October 25, 2007 3:32:26 PM(UTC)
vns
Dryer won't start. Timer still works. I thought of just relacing the starter switch and see what happens, but don't know if the door switch may be the problem, or something else. Don't want to spend for a service call on an old dryer. Any troubleshooting advice?
#2 Posted : Friday, October 26, 2007 1:35:29 PM(UTC)
Hi vns
You are on the right way. The first thing you have to check are the door switch and the start switch.
Keep me updated, please.
vns
#3 Posted : Friday, October 26, 2007 1:45:45 PM(UTC)
vns
Is there some way to check if either switch is working or not before I replace them? I don't have any meters but could borrow one (volt meter or ammeter) or whatever. Thanks.
#4 Posted : Friday, October 26, 2007 2:07:30 PM(UTC)
You have to check switches for continuity and you need a meter to do it.
Check the start switch for continuity across two terminals with switch in start position. If it's open, it has to be replaced. The bad news - the part is no longer available.
vns
#5 Posted : Tuesday, October 30, 2007 3:48:47 PM(UTC)
vns
Thanks Gene, story of my life, with the main switch being no longer available. I do believe that switch is OK and has continuity, if the meter is good, and I see you have a door switch available. How is that accessed? It looks small from your photo, with no wires. Does it just pull out (pry) or do I have to take the front of the dryer off? Thanks.
Guest (4)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Thermador oven won't start self clean (Oven Repair (including Ranges and Cooktops))
by beb123 2/6/2024 7:34:41 PM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
whirlpool washer wt5057lo powers on but won't start (Washer Repair)
by Guest 4/20/2023 4:19:14 PM(UTC)
Washer cycle won't start, motor just buzzes (Washer Repair)
by Guest 4/6/2023 4:46:53 PM(UTC)
Samsung DV42H5200EW/A3 Dryer makes loud buzzing noise and won't start unless (Dryer Repair)
by bvon 4/3/2023 9:46:22 PM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
my dishwasher won't start a cycle (Dishwasher Repair)
by Guest 1/13/2023 9:06:08 PM(UTC)
Samsung washing machine won't start (Washer Repair)
by Guest 11/14/2022 7:56:18 AM(UTC)
Maytag MDBH985AWS Won't Start Motor Humming (Dishwasher Repair)
by pdmac00 10/11/2022 12:48:23 PM(UTC)
Whirlpool WTW7500gc0 has power but won't start (Washer Repair)
by Guest 2/27/2022 2:52:51 PM(UTC)
Frigidaire dishwasher won't start, all lights are blinking (Dishwasher Repair)
by Guest 11/22/2021 4:33:30 PM(UTC)
dryer WED8300swo won't start (Dryer Repair)
by Guest 10/26/2021 10:24:13 AM(UTC)
Maytag LAT9600AAW Won't Start (Washer Repair)
by Guest 8/28/2021 6:11:33 AM(UTC)
