jmack123
#1 Posted : Tuesday, June 14, 2011 3:59:40 AM(UTC)
jmack123
Vent is clear and changing heat setting to lower setting doesn't seem to
make much difference. The case still seems too hot.
#2 Posted : Wednesday, June 15, 2011 2:30:11 AM(UTC)
Replacement parts for WHIRLPOOL GEQ9800PW1 27" ELECTRIC DRYER | AppliancePartsPros.com
First I would check the heating element.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 8 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high all the time.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
GEQ9800.pdf (253kb) downloaded 11 time(s).
jmack123
#3 Posted : Tuesday, June 28, 2011 6:35:54 AM(UTC)
jmack123
I cleaned and replaced the three sensors two on the heater box and the one
on the blower box. also checked the heater zero ohms to ground and 10 ohms
across the element. Could the drum seal be bad?
#4 Posted : Tuesday, June 28, 2011 11:39:00 AM(UTC)
Could be, see the following
http://forum.appliancepartspros...oo-hot-all-settings.html
I am assuming that the "0 ohms" (element to frame) is an error as 0 ohms would be a dead short.
So I am assuming you mean infinite ohms (open) which is what it should be.
jmack123
#5 Posted : Tuesday, June 28, 2011 12:01:51 PM(UTC)
jmack123
yes I meant open no contact one of those senior things so what else can make this dryer run hot? As I said vents are clean with good air flow three
sensors replaced heater checks good. any thoughts.
#6 Posted : Tuesday, June 28, 2011 3:08:59 PM(UTC)
[COLOR="DarkRed"]Could the drum seal be bad?[/COLOR]
The above could be it take a look at the link I sent earlier.
