Hey guys and thanks for the forum. I have a dishwasher in a rental unit that won't drain. The wash cycle works fine. Reached under the unit and felt of the drain pump motor and it's very hot to the touch, but not running. I'm assuming the motor is bad. What do you guys think?
Yes , it does sound like the drain pump is toast. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Yes , it does sound like the drain pump is toast. Thank You for the reply Denman. Glad I found this site, a lot of great info here. We will be ordering the part from appliancepartspros.com. Thanks again, Rodney
