From other posts, I see it could be a thermostat rather than heating element. Any suggestions for finding this out for sure?
Originally Posted by: Caldwell  From other posts, I see it could be a thermostat rather than heating element. Any suggestions for finding this out for sure? How can I be sure the heater is bad? At $50, I want to be sure.
Hi Caldwell According to the wiring diagram for your dishwasher it does not have any thermostats. The cause of the problem could be: a) The heat element b) The energy saver switch or c) The timer You can check all of them for continuity and find the wrong one. - The part number for the heater AP3102314- The part number for the energy saver switch AP2919490 - The part number for the timer AP3124204- Here are the break down diagrams for the Kitchen Aid dishwasher Model KUDC210S2Good luck. Gene.
