2 Pages12>
epows68
#1 Posted : Sunday, August 2, 2009 11:19:54 AM(UTC)
epows68
My GE model #wpre6100gwt washer will not spin or agitate. The electric water pump works fine and produces a good stream of water out the drain pipe. Continuity is normal through the magnetic lid switch, and 121 volts is detectable from the switch to the motor. The motor, tub, and transmission turn freely. The motor is clean and shows no sign of excessive heat. Is there a relatively easy way to check the motor without damaging the circuit board on top of it?
applianceman
#2 Posted : Monday, August 3, 2009 8:58:20 AM(UTC)
applianceman
There are two things that most often cause this:
  • That electronic board on the top of the motor stores fault codes and some of them will shut down the motor.
  • There is a fuse wrapped in tape on the right-hand side that could be blown. Since you have to cut the wires to test I would check this last.
This page will explain how to diagnose and repair both of these problems HydroWave GE Washer Repair Guide
epows68
#3 Posted : Monday, August 3, 2009 5:39:54 PM(UTC)
epows68
Resetting the codes worked. The machine appears to work normally now.
Thank you so much.
cc49
#4 Posted : Monday, June 27, 2011 2:48:57 PM(UTC)
cc49
hI, i ahve exactly the same problem with my model Ge washer won't spin or agitate after fill up help what is that?????? i need to wash clothes
epows68
#5 Posted : Monday, June 27, 2011 5:36:08 PM(UTC)
epows68
I was able to get my washer working again by clearing the error codes. My problem was apparently caused by a power interruption.
[FONT=&quot]To clear the error codes, turn the washer off. Disconnect power for about 20 seconds (pull the plug). Next, reconnect power and then open and close the lid five or more times within 12 seconds in the first 30 seconds of power-up.
As crazy as this sounds, it should work if your model has the same electronics and if this is the only problem. If this fails to work or the problem is recurring, you may need on-site technical assistance to repair the problem.
[/FONT]
cc49
#6 Posted : Tuesday, June 28, 2011 6:00:46 AM(UTC)
cc49
Hi i tried that the code says that the motor is stuck i don't know how to do that and get the agitator off the machine any help there???
epows68
#7 Posted : Tuesday, June 28, 2011 5:41:42 PM(UTC)
epows68
I'm sorry. I can't help you here. I personally leave the disassembly of these newer appliances to someone with more expertise and patience than I have.
cc49
#8 Posted : Wednesday, June 29, 2011 4:13:36 AM(UTC)
cc49
Hi thanks anyways it's working now i guess we just didn't do the 1st reset right after sitting all night went back down & tried it again and yeah!!!!!! it works..seems like the lid switch cause it blinked 7 times thanks
applianceman
#9 Posted : Wednesday, June 29, 2011 5:29:42 AM(UTC)
applianceman
The light blinking 7 times means that the lid switch is stuck because the motor detected that the washer has been through the cycle 4 times and it hasn’t detected a lid opening. If the lid switch is bad the code will reoccur after 4 wash cycles. Sometimes these motors will flag an error for no reason so it may not come back and I wouldn’t worry about unless it does come back.
This page will show how to test the lid switch. http://www.appliance-repair-it.com/GE-washer-repair.html If the circuit fails to open with the lid up you need to replace the lid switch.
damikkobek
#10 Posted : Monday, October 17, 2011 11:38:13 AM(UTC)
damikkobek
I HAVE A COMERCIAL FREEZER VERTICAL ONE DOOR BRAND "SUPERIOR PRODUCTS" THAT WHEN IT DOES ITS DEFROST CYCLE WATHER LEAKS ON THE INSIDE. WHAT COULD IT BE?
Guest (4)
GE washer won't spin or agitate. (Washer Repair)
by Eric9999 12/21/2015 10:19:03 AM(UTC)
GE Washer won't spin or agitate (Washer Repair)
by whovian2015 9/30/2015 2:56:35 PM(UTC)
GE washer won't spin or agitate (Washer Repair)
by unclejohnforever 2/27/2013 6:58:56 AM(UTC)
Ge washer won't spin or agitate (Washer Repair)
by Pwat300 12/3/2011 7:20:57 AM(UTC)
GE washer won't spin or agitate. Motor? Mode shifter? (Washer Repair)
by kzinti83 9/11/2011 4:57:09 PM(UTC)
by Soknows 5/24/2011 11:17:21 AM(UTC)
by mhilbeli 4/7/2011 4:38:33 PM(UTC)
ge washer won't spin or agitate (Washer Repair)
by agrimmer 2/19/2009 3:32:00 PM(UTC)
2 Pages12>
