billychandler01@yahoo.com
#1 Posted : Thursday, June 23, 2011 7:38:21 AM(UTC)
suddenly one day oven is inop, digital display works fine, top burners work fine and broiler working. when try to start oven no heat and no pilot/ignitor. Any help?
Bill
Joe / APP Team
#2 Posted : Thursday, June 23, 2011 1:05:31 PM(UTC)
Joe / APP Team
Bill
Bill,
A good guess, would be a weak or bad glow bar igniter, on the bake burner.
But, you saind the igniter won't glow, so it could also be a bad relay on the clock, or broken wire.
With a proper and complete model number, we could assist you more efficiently.
#3 Posted : Monday, June 27, 2011 12:15:23 PM(UTC)
Joe, thanks for the reply, the complete model # JGBP90MEA2BC.
Thanks, Bill
#4 Posted : Monday, June 27, 2011 12:17:41 PM(UTC)
Sorry Joe one more thing is the igniter in the same place as the broiler igniter?
Joe / APP Team
#5 Posted : Monday, June 27, 2011 2:02:57 PM(UTC)
Joe / APP Team
Bill,
Yes, the igniter is located in the same general area and is mounted similar to the broil igniter.
Here is the part number you need for the bake burner igniter,
Part number: AP2014008
You'll need to remove the oven racks, and the oven bottom panel to access it, and, with the oven door removed, it's a lot easier.
If you can get access to a multimeter, when you disconnect the two(2)wires from the igniter, if you can attach the meter leads to the two(2) wires coming from the cabinet harness, you should be able to read 120 VAC across the wires when you program the control for a Bake cycle, that will confirm if we have a good relay on the control.
Let us know how things work out.
Good Luck,
#6 Posted : Monday, June 27, 2011 4:30:44 PM(UTC)
thanks for your help
Joe / APP Team
#7 Posted : Tuesday, June 28, 2011 5:08:33 AM(UTC)
Joe / APP Team
Bill,
It's our pleasure to help.
We're here if you need us.
Thanks,
