Bish107
#1 Posted : Monday, December 1, 2008 5:00:06 PM(UTC)
Bish107
in spin mode, makes a winding sound. in agitating mode, it does nothing. which part assemblies do i need
Eddie365
#2 Posted : Monday, December 1, 2008 6:02:29 PM(UTC)
Eddie365
Hi.
check that you door is closing the lead switch.
if that is ok, check your coupling 1-5 years is probably broken.
#3 Posted : Tuesday, December 2, 2008 1:17:19 AM(UTC)
If the lid switch is ok, I would check the water level switch, you will need a meter for this. Your timer is pretty reliable, but might be bad.
